ADJUST MAF T ???
On another note I would adjust base setting to 20 % rich and take it from there.
<strong>After i had my long tubes installed, i contacted super chips..... they wanted an additional 275.00 to 300 $$$$ to reprogram the "chip" said if i didnt do it i would have problems with it running right with the addition of the long tube headers. so i UN PROGRAMED THE super chip, put it back to stock and the readings from my dyon is what you see. SO.... YOU ARE SUGGESTING to go with the base at 20% rich and leave the wot at 0 at this time?? sure can give it a try. thanks.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you have to bias the MAF signal to -20,
that says your injectors are too small to handle spiking during WOT, makes PCM believe there is a much higher engine load, thus less timing and costs you torque, if auto trannie, lower line pressure and could cold misfire during certain fuel trim cells where it was closer to 0 LTFTs before making that much of a MAF signal change.
<strong>JOHN, Yes its an a4 trannie. i have the hhpIII BUT ONLY ADJUSTED THE TRANNIE % TO 75% FOR FIRMNESS........ did not use the power programmer part as i will not work well with a ported/polished throttle body. dont know if this helps, the sae #s for my car is 321.9 for power and 330.7 for torque. suppose to pich up around 8-10 hp from getting the air/fuel adjust correct, plus will just preform better. so do you agree that a good start would be to start the base at 20% rich?? terry.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Terry to get the best results using a MAFT you need to do some work using a decent PCM scanner and see really how rich or lean the powertrain is across the RPM/engine load range.
Also with scanner record the injector pulse width for both heads. If you see pulse widths near or above 18 mSecs then your injectors are being driven over the recommended 80% duty cycle and and forcing the PCM ( via lying to PCM via a high change with MAFT) to go so much richer will not give you the best overall tune for part throttle and PE (WOT).
The lower ( less) air the PCM thinks ( forcing richer) there is, the less torque and line pressure.
So if your in the game you gotta do the PCM recording and analyze what truely is going on for the MAKEUP of YOUR powertrain and not what was best for someone elses powertrain for a simple thing as they being a sealevel and you at 3,000 ft means their adjustments are not best for your's
Sorry I do not trust chassie dyno results esp for AFR for some 02 sitting in a muffler tip is not good enough to get true AFR values so use the scanner and judge the part throttle AFR, dial it in ( if it is not overdriving present injectors) and only then work on PE conditions.
