ls1edit?
Old Aug 7, 2002 | 01:00 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: ls1edit?
What do you mean by “needs”?
I have a Thinkpad 380XD Pentium II 233 with 96MB of RAM. It works just fine.
You will also need WinZip up unzip the files and MS Word to read the Programmer instructions. The laptop will need an RS232 serial port for the cables.
Was that what your were asking about?
<small>[ August 07, 2002, 01:01 PM: Message edited by: RPM WS6 ]</small>
Old Aug 7, 2002 | 04:01 PM
justin sutton's Avatar
Thats what i needed to know thanks for the help.
Old Aug 8, 2002 | 12:52 AM
Default ls1edit?
Wondering what my laptop needs to run ls1edit as far as programing.
Old Aug 8, 2002 | 12:58 AM
Camaroholic's Avatar
P133 MHz or higher, 32MB of memory, Win98 or higher, serial port (9-pin D-shaped male). That's the *minimum*. If you don't have a serial port, you'd probably need a USB to RS232 adapter, but if you don't yet have a laptop, be sure to specifically look for a computer that has the RS232 plug on the back.
I'm probably going to get a lower-end PIII Panasonic Toughbook one of these days for in-car stuff.
-Andrew
