Need help with these codes!!
P0410: Secondary Air Injection System Malfunction
P0412: Secondary Air Injection System switching valve A circuit malfunction
P0418: Secondary Air Injection System Relay "A" circuit malfunction
https://ls1tech.com/ubb/cgi-bin/ulti...;f=23;t=000371
The air pump right have just quit, make sure the tub that goes to the check valves are not crushed/ripped.
The strut on my hood smashed the main hose going to the check valves and I tripped a secondary air injection code
“We don’t have inspection’s here; but I was thinking why not use an maft to set the base way lean. Just hope who ever is in inspecting the car does not know what that little box is. If you have a SES light just clear it before you drive up for inspection” <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
<small>[ August 07, 2002, 11:38 PM: Message edited by: dissonance ]</small>
P0410 - Circuit Description
An AIR pump is used on this vehicle to lower tail pipe emissions on start-up. The PCM supplies a ground to the AIR pump relay, which energizes the AIR pump. The PCM monitors the HO2S voltages to diagnose the AIR system.
During the AIR test the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors the HO2S voltages and short term fuel trim values for both banks of the engine. If the AIR system is operating properly, the HO2S voltages should go low and the short term fuel trim should go high.
If the PCM determines that the HO2S voltages for BOTH banks did not respond as expected during the tests, DTC P0410 sets. If only one sensor responded, the PCM sets either a DTC P1415 or P1416 to indicate on which bank the AIR system is inoperative.
P0412 - Circuit Description
The PCM controls the relay by grounding the control circuit via an internal switch called a driver. The primary function of the driver is to supply the ground for the component being controlled. Each driver has a fault line which the PCM monitors. When the PCM commands a component ON, the voltage of the control circuit should be low (near 0 volts). When the PCM commands the control circuit to a component OFF, the voltage potential of the circuit should be high (near the battery voltage). If the fault detection circuit senses a voltage other than what is expected, the fault line status changes causing the DTC to set.
The relay controls the high current flow to the AIR injection pump integral bypass valve. This allows the PCM driver to only have to control the relatively low current used by the relay.
P0418 - Circuit Description
The PCM controls the relay by grounding the control circuit via an internal switch called a driver. The primary function of the driver is to supply the ground for the controlled component. Each driver has a fault line which the PCM monitors. When the PCM commands a component ON the voltage of the control circuit should be low (near 0 volts). When the PCM commands the control circuit to a component OFF, the voltage potential of the circuit should be high (near the battery voltage). If the fault detection circuit senses a voltage other than what the PCM is expects, the fault line status changes causing the DTC to set.
The relay controls the high current flow to the AIR injection pump. This allows the PCM driver to only have to control the relatively low current used by the relay.
***Also, in the troubleshooting section, it says the following:
If DTCs P0412 and P0418 are set at the same time, inspect the AIR pump fuse for an open. If the fuse is open repair the grounded circuit.
I'll email you the whole thing - too much info to post.
