shift point question and ls1edit, why so many tables
Old Aug 7, 2002 | 10:36 PM
parish8's Avatar
single digit dreamer
Default shift point question and ls1edit, why so many tables
when i bring up the trans calibration table it has a nice chart right off the bat that has all the shift points on it, up shifts and down shifts and diferent modes also. then when i click on the big charts that have all the throttle positions on them i see diferent numbers. what numbers do i use? can i forget about all of this and just use the rpm part?
my truck downshifts right into the rev limiter, with a whipple this must be bad, i need to change the 2-1 downshift mph and no idea which one to change, looks like there are 7 places that could be changed.
Old Aug 8, 2002 | 08:01 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: shift point question and ls1edit, why so many tables
Change the WOT boxes (mph & rpm) and change the 100% TPS mph settings to match what you put in the WOT boxes. That is how mine is set up. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
