hypertech???
Old Aug 8, 2002 | 01:55 PM
ls1ss's Avatar
Default hypertech???
is a hypertech programmer worth that much on a
stock motor with bolt ons???
Old Aug 8, 2002 | 01:59 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: hypertech???
A4 or M6? If A4, then yes if you want or need to change your shift points.
If M6 then it’s really worth very little on a bolt-on car.
Either way, I’d rather have Edit. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Aug 28, 2002 | 02:41 PM
Bill's Avatar
Yes to the HPP3, if you don't feel like programming &/or don't have a notebook. With an HPP3, it's much harder to screw things up. But if you're a purist, go with LS1_Edit . . . the crowd here is very patient and knowledgeable. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
ND4SPD's Avatar
Looks like you guys haven't been doing your homework and reading the newest GM hi-tech issue p.46. They added the PP3 to a basically stock ta and got 10.9hp & 15.9 lb/ft at around the 3000 rpm mark. I'd say that's a pretty substantial gain without even getting your hands dirty!
Check it out.
Old Aug 28, 2002 | 09:41 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
I agree. If you are very computer savy then LS1 edit is great, but for those less inclined like myself, the HPP3 is a very useful tool. I gained most from the increased shift points, power tuning (which increased the timing a bit), and lowered fan temp settings. It showed on my ETs. Good luck.
James
Old Aug 29, 2002 | 12:56 AM
robertbartsch's Avatar
NO! Buy LS1Edit instead!
