Basic parameters adjusted to increase hp?
-air/fuel mixture - try to get 880 - 890 at wide open throttle (I thought that was equivalent to around 12.8 to 1 air / fuel ratio.
-timing - try to get 29 - 30 degrees of timing at wide open throttle (if engine permits (no KR)).
Is this accurate? Is there more?
Thanks
http://ls1edit.slowcar.net/
You really can't tune for WOT with the factory O2's. They are not accurate at that A/F ratio.
