PE & OLFA (pid)
Actually now that I have a wideband, I want to learn the SD tuning. But if I can get this leaned out. I am good to go.
I bet you would see some more power Ed if you would convert to a SD/2bar tune using Live. You can do SD tuning, but its not easy and really a pain in the *** with Edit. You already have Live's scanner. I would just pay the upgrade fee for commerical and you'll be all set. You have invested a lot of money in your setup as it is, whats a little more to get it to run better?
Actually it runs pretty good. Just a bit rich. If it ran like ****, I would have switched to SD a long time ago.
I think we'll be able to figure something out. Have you started painting the rear yet? if not, ill be there sunday to work on it if thats cool, i guess i can help you out in the process.
i gotta go pick up my swaybars about 4pm from Frys
...or you we could get together and use my HPT EIO/cable/LC1...
Lemme know, I'll be around the house today working on the car.
...and Nino and I and SDFB Ben can probably help with the tuning how-to.
Rob (Bad30th)
I already use the keyspan adapter. Did you ever switch to SD?
Rob (Bad30th)
I am now offically CARB legal, JBA coated shorties and stock Y-pipe and cats. I wanna see how much power I can make with em.
I will start retuning this week... Still have the one bar MAP, I am gonna try to just tune A/F with PE since I'm only running 9-10psi (well, probably 10-11 now with that stock exhaust back on...)
Rob (Bad30th)
