LC-1 Calibration
Just a thought here............do i need to have the HPT connected and running and the LC-1 connected to my laptop at the same time? IF so then I need another serial-USB adapter since my laptop does not have any serial ports on it.
All info will be really really appreciated!
Dave
As for the LC1 software, yeah, make sure you connect with the log software first to chose the com port. If thats ok, then the configuration tool will usually connect ok. I found you have to do the log software before trying the config tool.
Its easier just to wire up the push button and use that, than mess about with the software and serial cable.
Dave
some people also need to download logworks 2 as it used to ship with logworks 1
then you should be able to get into the programmer side
Dave
Dave
Thanks,
Bill
sometimes helps to take a hairdryer to the rubber and soften it up a little
I hardly ever use that connector as I have the LC-1 wired through FlashScan. Only time I use it is when I want to verify the readings in EFIlive.
