Can atap or edit tell what timing table?
Example: My car makes 22 timing max at 5000 WOT with the "Good Gas" table.
It makes 15 deg on the "Pond Water" table.
If I Atap and see 16deg or more at 5000, I know it was on the "good gas" table.
HOWEVER... If the number is 15 or less, you have to check IAT (intake air temp) and KR. You can pull alot of timing with those 2.
So if the IAT table says you are pulling 7 deg and no KR, then you would be at 15 deg even though you are on the "good gas" table. Likewise with the KR.
<small>[ August 17, 2002, 04:45 AM: Message edited by: McRat ]</small>
