How is a car PROPERLY tuned??
Old Jan 22, 2006 | 02:12 PM
macsperformance's Avatar
Originally Posted by hurley711
OK then let me rephrase the Q.....Can I get a good solid tune if someone uses the LS1edit program on my car? Plan would be to tune it after cam install, run it on a dyno to check A/F and wideband, then retune to tweek the initial tune. Would this be alright and give me a good solid tune?
Yes sir it would just fine to calibrate your ECU with after a camshaft installation.
Chris Macellaro
Old Jan 22, 2006 | 03:26 PM
hurley711's Avatar
Thanks buddy
Old Jan 22, 2006 | 05:29 PM
BLK02WS6's Avatar
You can get an alright tune with LS1 Edit if the user knows what they are doing - but you won't get a really good tune because there is no way to integrate a wideband into the tuning process with LS1 Edit. Using a wideband to tune WOT on the dyno will make it safe at WOT, but won't give you near the tune you can get using a wideband through the whole tune.
I work at a shop that used LS1 Edit when I started tuning there - I quickly changed that to EFILive FlashScan with a wideband to tune each car from idle to WOT and the tunes are far and above the old way of doing things. I have retuned several cars that were done originally with the old way and the customers can't get over how much better the car is from idle on up. Do it right and you won't regret it!
Old Jan 22, 2006 | 07:41 PM
Not to start a debate or conflict friend...just sharing information though
I respectfully disagree with your opinion on wideband integration as my opinion is this:
When I have a vehicle on the dyno I always use the information from the dyno's wideband unless I feel reason to doubt its displayed information. Yes the difference you will see from on dyno to out on the street information about the A/F's will normally be of a small difference. My point is in my opinion I put more trust in a wideband that I use several times a week and know the validity of the readings than a different unit in every car.
If I get a FAST, BS3, Gen7, Haltech or a Greddy Emanage or any other system I always use the wideband data to tune with (again unless I have reason to disbelieve the sensor information).
Chris Macellaro
Old Jan 22, 2006 | 07:49 PM
Bink's Avatar
Chris Macellaro
Chris - are you tuning with an Eddy Current/Load dyno?
Old Jan 22, 2006 | 08:05 PM
BLK02WS6's Avatar
Chris Macellaro
I think you are missing my point. What I meant was that with the wideband integrated into the software, you are using a wideband to tune each and every cell in every table you work on (VE, MAF, etc). The overall tune is much more accurate and the idle, throttle response, driveability and gas mileage will all be greatly improved. You just cannot get that kind of tune using the dyno wideband to tune only the WOT areas of the tables.
Also, I use the same wideband too - I weld a bung in each car and use my portable wideband that integrates into my laptop/tuning software. So I can calibrate the wideband each time I use it and maintain/replace the sensor as needed.
Old Jan 22, 2006 | 09:01 PM
Yes that is what I prefer to tune with. On WOT stuff I will on occasion use an inertia based dyno if that is what a customer wants. I meant to state that in my above post sorry friend.
Chris Macellaro
Old Jan 22, 2006 | 09:08 PM
No friend I understand your point of view. But from the way I understand your post you are referring to an inertia based dyno talking about only being able to tune for WOT. The dynos I prefer to use can steady state load for all of the things you spoke about.
I am working on something to help educate people about load cell tuning on a dyno that is load bearing. As soon as I finish it I will post a link to a site that I am a vendor on so you can see the information and come to a conclusion about it for yourself.
Chris Macellaro
Old Jan 22, 2006 | 09:13 PM
Bink's Avatar
Chris Macellaro
Thanks. I may have to look you up if/when I switch engines.
Old Jan 22, 2006 | 09:18 PM
WS6FirebirdTA00's Avatar
Originally Posted by Alvin
I think you would be surpized if you compared the same wideband on the dyno as off the dyno. What a LC1 reports and what a dynojet wideband reports are 2 different things.
im was just going by what people told me that use LC-1 on and off the dyno and have seen some big changes, mostly at higher speeds with some sort of ram air setup. not doubting what you are saying i was just going by what i have been told since i have yet to get on a dyno
Old Jan 22, 2006 | 10:02 PM
pkincy's Avatar
So LS1edit isn't gonna give me a real good tune then, I'll probably ending up getting it tuned again in the long run?
LS1Edit and a wideband will certainly do it. Particularly if you are a novice.
What people are saying is that once you get to be a good tuner the other tuning software packages are more capable, cheaper and easier to use.
By your questions, it is apparent that LS1Edit will work fine so long as your friend has some knowledge of what he is doing.
Kinda like asking if you should use a 34 or 36 oz bat. For a non baseball player either will do. When you get really good you will have a preference.
Perry
Old Jan 22, 2006 | 11:12 PM
  #32
ws6togo's Avatar
Originally Posted by joecar
Using HPTuners or EFILive and a wideband oxygen sensor (e.g. LC-1, PLX, Autronic, Tech Edge, etc...) you can perform an "automated" VE tune which is a very easy procedure and produces very good results.
Purchasing the above is money well spent, you'll learn about tuning, you'll be in control of your tune, and you'll wonder how you got by without.
I have EFILive flash and have been playing around in the tune area. Is the process for tuning the car really that easy with the wide O2. You make it sound like clicking a button on the screen and it tunes the car for you?
Old Jan 23, 2006 | 05:33 AM
  #33
BLK02WS6's Avatar
Chris Macellaro
Actually, I was referring to the tuning software capabilities, not the dyno. I understand the difference in a load bearing dyno vs. inertia dyno. A load dyno is definitely a better tuning tool. I was referring to the ability to take wideband readings and correct each cell of each table of the tune - to do that with LS1 Edit and a wideband reading that is not integrated into the scanning/tuning software would be extremely time consuming at best. But to each there own...
Old Jan 23, 2006 | 10:36 AM
  #34
joecar's Avatar
Have you seen the Auto VE Tutorial on the EFILive doc site...?
Install a WBO2, set up Auto VE tune mode, drive and log data, apply filters, paste with multiply.
It's not a single button, but it's not difficult.
Old Jan 23, 2006 | 09:50 PM
  #35
Slowhawk's Avatar
LS1Tech Sponsor
Yes,you can get a real good tune-depending on the tuner of course.
It might surprise alot of people here but not everyone want's to tune there own car The problem is that alot of shops/tuner's rush you in/out with the tuning and collect the $$.
Now,with LS1 Edit you can get a precise tune easilly enough.Probly not as straight forward as HPtuner's but it can be done.All my race/street cars get tuned on the street and never hit the roller's.The dyno is definitely not something to really go by if you want to go fast at the track Also,a wideband is not necessary if you have the right scanner's knowledge about the setup's.Some cars like 14-1 A/F at WOT and some like 12-1 (NA of course).It all depends on the H/C being used.
Right now I'm at the end of ussing Edit mostly due to the way our tuning is pointed.400-700rwhp cars are a thing of the past and now the setup's are hitting 800-1000+hp which we need 2-3 bar tuning capability.
Old Jan 23, 2006 | 10:25 PM
  #36
ws6togo's Avatar
EFILive is capable of doing the 2-3 bar tuning. Have you looked at it?? www.efilive.com
I am not an expert with it by any means but I know there are some out here that use it. I am still in the "newbie" stage with it. You can download the demo for free and get a feel for how it works.
Old Jan 24, 2006 | 10:51 AM
  #37
joecar's Avatar
You can learn this from experience, but a DIY will typically own one or two cars and so won't be able to gain as wide an experience; so while a WBO2 isn't required, it will help a DIY achieve good (and safe) results for less than $200.
Sure, there are a lot of people who do not want to tune their car, and this is where they have to research and find a shop that does the job properly;the rest of us can't leave our cars alone, so we're going to tune as best and as much as we can.
P.S. Nice purple kid's street rod, wish I has one when I was that young.
Old Jan 24, 2006 | 12:58 PM
  #38
ws6togo's Avatar
Default Wb02
Which WB02 do you recommend ?? Looks pretty easy to install. but looks like it needs to have a display hooked to it to be able to see a/f output, or does it show on laptop? Referring to the LC-1
Old Jan 25, 2006 | 10:41 AM
  #39
joecar's Avatar
There are various WBO2's out there, they're all good, you'll have to read people's reviews or take a poll (LC-1, PLX, Autronics, Tech Edge, and others).
It's not difficult to install, the hardest part is routing the wires to inside the cabin, and that's not too hard; you need to read the instructions that come with and search LS1Tech for people's experiences.
You don't need a display unless you want one;
the wideband signal goes to the HPTuners or EFILive modules so that their software packages can log this signal, and then you create a histogram/map of the correction which you then "paste with multiply" into your VE table (of course you must first setup your tune for "Auto VE Tuning", i.e. SD open loop).
Old Jan 25, 2006 | 11:05 AM
  #40
ws6togo's Avatar
So as long as I have the Auto VE tuning done I can then do the WB02. Is there anything else that I should make sure is setup good before doing wideband?
