How is a car PROPERLY tuned??
the WBO2 tells you the actual AFR and the Auto VE tuning procedure uses this to correct the VE table.
1. Use the Spreadsheet to make sure the IFR table is correct.
2. Install WBO2.
3. Do Auto VE Tune, and apply correction to VE table.
4. While still in Auto VE Tune mode, log MAF freq data and create a new MAF table.
5. Use WBO2 to adjust PE.
6. Play with spark timing to see how much advance works for you without knocking.
7. Hmmm, what else...
You can run SD (no MAF) or MAF'ed.
Some people also like to run in OL.
You can have all the tools in the world, but you have to know how to use them correctly to get the job done. The "easiest" tuning software to use sometimes gives the user a sense of over security sometimes I think
A car is properly tuned when it goes down the track making max power as reliably as the setup should be expected - and driveability is on par with what the customer is after.
I can do the same "really good tune" with LS1Edit that I did on ATVRacers car with what I normally use (HPTuner). It might take a few more iterations, but when done it would be just as consistant 9.7-10.0 car (how many heads/cam mild nitrous shot cars were as consistant as Waynes car? Track days where it made 8 passes within .04 hundreths)
Its more so the tuning tool behind the tuning tool that makes it happen
Just like any other tool, the skilled craftsman can create works of art, while the rest of us (me) practice alot.
and a good tool with good features helps the DIY, and a DIY tune is as good as the research put it and the amount of time spent logging on the street;
besides the Scan/Tune tool, another good tool is the WBO2, gives the DIY a very good bang for buck.
a. researched topics,
b. right tools (log/scan/tune/wbo2),
c. street time,
d. dyno time for WOT (if you go to the track),
e. being open to ideas (SD)
The actual methods may vary, and different methods give various results (good/better/best),
and forum searches show which methods give good/easy/consistent results.
There are plenty of tuners that refuse to embrace technology and still use cumbersome software, refuse to use a wideband for anything but WOT (or some at all), or still tune with IFR tables and PE. If that is the way they like to do things, more power to them.
It isn't about using the "easiest" tuning software - it is about using the tools that give the most accurate and complete picture of what the car wants from idle to WOT and then enabling the tuner to effectively use that information. Tuning the car to go down the track is one thing, but tuning it to be enjoyable to drive to and from the track is another.
Personally, I use what gets the best results for me - and my customers are happy for it. That is all that really matters to me.
This is a separate thread on this issue, any suggestions guys?
Wrong size screwdriver ("easiest to grab out of toolbox") still allows you to drive a screw, but not as efficiently as the right size one ("must sift thru toolbox to find").
I am not sure i understand you when you say you think some tuning tools give the user a false sense of security can you explain? You yourself have since stopped using LS1Edit in favor of HPT and you surely can be saying HPT gives a false sense of security or you would contnue using Edit. So what do you mean?
A bad tuner cant tune a car even if he has HPTuner or EFILive with or without a MAF, SD or 3 bar MAP setup, a full color instruction manual and a video tape
Like any other part of building a car for example you cna give 2 guys the same suspension pieces and one can get the car to hook and the other guy cant. Its the sum of the parts and user, ala my previous statement "The Tool and the Tool behind the Tool"
