ltrims=25%
Could be a vacuum leak...
"post back with more info"
Looks like you are very rich but what I'd do is borrow a MAF T and track test it.... run stock.... change the WOT... drive the car a bit, and come back...
Anything in the 7-10% is fine.
car likes to surge when i let off the gas quickly which leads me to believe its dumping too much fuel in.
i am borrowing dann00hawks maft john.
I don’t know if everyone will agree with me but your ltrims should be around 0% at idle - I would say negative decimals are safer “pinging, burning valves/pistons
With my 85mm maf I run at 0% to -1 or -2%, at part throttle I run way to lean with it. Stock maf with a screen is dead on most of the time.
You might run a little rich at WOT and have a vacuum leak, my egr had a small leak around the pipe that runs in to the intake. I could hear the leak but I had a hard time finding it. Rev the engine and watch the ltrims, if the number shoots up to like +15% or more then come back down I would say you have a vacuum leak.
While the engine is running take a cigarette and move it around the vacuum lines, or any place that is behind the maf. If you see the smoke being pulled, then you know you have a leak in that area. Crab cleaner does the same things, when you spray it around the leak the motor will raise the idle a little.
<small>[ August 23, 2002, 08:51 AM: Message edited by: dissonance ]</small>
Try lessening for a hissing sound from the breather area
<small>[ August 23, 2002, 08:55 AM: Message edited by: dissonance ]</small>
EGR and PCV are the usual major sources of vac leaks. Check seal between MAF and T-body.
Cheers,
Chris
ps- you will pick up a lot more when you fix the problem.
Ended up buying a new one from gm. it was only $98
What year is your car?
i ran the ltrims again. i found a total of FOUR different ones. i used the B1 and B2, one was at 0 the whole time, and the ohter was just an extra B1. at idle it was at 25%. i would rev it up and it would drop to about 17% at 2400 rpms. let off and it floated around a little before stopping at 25%. i plugged the maft in and played with the settings. nothing made a difference at idle- 850ish-900. Sometimes i would blip the throttle and let off and it would hover around 22-23% on some of the settings. at part throttle the numbers would go DOWN as i made it richer, and go up as i made it leaner. the fans were on so i couldnt test the smoke.
2%leaner means it will make the car 2% leaner, right. just so i know im not an idiot and doing it wrong.
Make sure you have the LONG TRIMS bank1, bank2 NOT THE SHORT TRIMS
Turn your BASE and WOT to 0%
You might want to try to reset the pcm before you do this. if you do reset; drive the car around for 30 min's or so.
Start the car and let it warm up. It should only take a min or two for the o2 sensors to start reading lean/rich.
Once your ready turn the base to 5% rich if your ltrims are +. 5% lean if your ltims are rich. Positive numbers are lean/ negative numbers are rich
Once you have made the adjustment the ltrim should have gone down some “2%-4%.
Repeat this until you get your ltrims around 0% to -2%
I would replace your ported ends with the stock ends and screen. I talked to a guy making over 400rwhp with the stock maf ends/screens
Once you feel that you have got the LTRIMS down. You should end up with no more then 15% rich. If you have to add more then 15% you are most likely still pulling unmetered air in.
Don’t worry about your WOT o2 reading yet, get everything lined out before you start moving up
Here is a great link on this subject
http://www.ls1info.com/article.php?sid=163
<small>[ August 23, 2002, 10:46 PM: Message edited by: dissonance ]</small>
