Rear ABS and VSS...can it be the same?
Old Aug 21, 2002 | 07:33 PM
Gold Phoenix's Avatar
Default Rear ABS and VSS...can it be the same?
I am looking to get a new rearend like the Ford 9" with a spool or locker, but the only ABS sensor system they use is the 4-channel. I on the other hand have the 3, which senses the ring gear speed. Is there a way to have the signal for the VSS simulate the rear ABS signal? Or maybe have 4-channel modified for 3-channel? I don't want that ABS INOP light, but don't want to take the bulb out.
Old Aug 24, 2002 | 11:43 AM
wrencher's Avatar
wrencher
Default Re: Rear ABS and VSS...can it be the same?
Wouldn't a 12 bolt be alot easier & cheaper?
Old Aug 24, 2002 | 07:44 PM
I have heard too many 12-bolt failures with the M6. I am planning to install a turbo system and have a mjor amount of torque. I don't want any doubt about the Ford 9 not breaking. Besides, in the 12-bolt I can't get a 3-ch ABS with the spool.
