MAFT and the infamous P0102 Code Help
Old Aug 29, 2002 | 04:53 PM
Z06PSI's Avatar
Default MAFT and the infamous P0102 Code Help
Just installed the MAFT 5.2 (awaiting autotap) and It automatically threw the P0102 code. Checked all wires and the dip switches are all at 0 and off. Reset PCM and the code still comes back. Checked the Eng Sns fuse and it was good and the connector on the MAF is on right. Anybody have some ideas. BTW my MAF is ported and polished but it was done about 2 months ago and no code.
Old Aug 29, 2002 | 05:12 PM
Z06PSI's Avatar
Default Re: MAFT and the infamous P0102 Code Help
O.K. Here is some more info. Take the MAFT out and wire up the MAF regular and still same code. Could someone have sold me a defective MAFT? and Made my MAF go bad? Any help would be appreciated.
Old Aug 29, 2002 | 05:23 PM
Z06PSI's Avatar
Ignore the last post. MAF good now no code. So WTF when the MAFT is wired in.
Old Sep 1, 2002 | 11:02 AM
98blackSS's Avatar
MAFT may be toast. It still do it with both settings at 0 (pass through)?
Old Sep 1, 2002 | 07:48 PM
cobray's Avatar
Did you disconnect your negative battery cable before you installed the MAFT? If not, that is probably the source of your code.
The PCM will throw a code if you disconnect the connection to the MAF and the battery is still connected.
Old Sep 3, 2002 | 11:47 AM
Frank's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by cobray:
<strong>Did you disconnect your negative battery cable before you installed the MAFT? If not, that is probably the source of your code.
The PCM will throw a code if you disconnect the connection to the MAF and the battery is still connected.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Really? I didn't disconnect the battery when I installed my MAFT and have disconnected the MAF before without any codes. Hm.....what am I, lucky?
Frank
Old Sep 4, 2002 | 12:52 AM
redrumss1's Avatar
Found out what was wrong. The person that sent me MAFT gave me the directions with backward wiring diagram. I am not blaming him though should have checked with the manufacture first. Well I checked with them and rewired and all is fine now.
