Injector Wiring ???s
I have replaced all of the wires on the injectors that go to the battery with 14 guage wire (this was recommended to me by the maker of the converter).
When I looked at the fuse box there are (2) 15 amp fuses…1 for injector bank #1 and 1 for injector bank #2.
My plan is to wire the 4 injectors on one side together and run it to the #1 fuse and wire the other side together and run it to the Injector #2 fuse. Does this sound like it will work?
I think that all of these just need to see switched power and that computer takes care of opening the injectors by grounding the other lead into the injector.
Thanks,
Scott
