Need SES help!
*This DTC sets if the engine runs out of fuel.
*A fuel delivery malfunction causes this DTC to set.
*If DTC 171 is also set indicates both banks of the engine are operating lean. Inspect items that would cause both banks to operate lean.
*A vacuum leak will cause DTCs P0171 and P0174 to set at the same time. Inspect all areas of the engine for a vacuum leak. Also inspect PCV valve for being the correct one for this application. Make sure the engine oil fill cap is in place and that it is tight. Inspect that the engine oil dip stick is fully seated.
