strange idle problem
- PCM has been tuned by 2 different vendors.
- TB, TB sensors and MAF have been swapped.
- O2's 990mv+ WOT
- Codes po171.po174, p1336
Problem still exsists. He has LS1 Edit now to make any changes. Mods are: TR224, LS6 intake, longtubes, ported TB and SLP MAF
Any help would be greatly appreciated.
Larry
Anyhoo, if it started after your intake install it should be something to check for. Get some carburator cleaner (or starter fluid, basically some highly volotile ****) and spray it around the intake. If the idle goes up, you know you have a vacuum leak.
Make sure you do this when the car is STONE COLD. There's nothing like the fireball that errupts after starter fluid hits a hot exhaust <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Good Luck
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
We have also found the "Bad VSS" rev limiter set for 6200 in the program which my explain why the car hits the Rev Limiter at 6200 instead of 6600.
Thanks
Mark
