Injector Offset Adjustment
>Would you mind expounding a little on what and how
>to recalibrate the offset tables.
Curious to see what others think about this.
If you knew what the idle trims were prior to the
injector swap, and believed the original offset and
flow table and your new flow table, then the easiest
thing might be to back into it using the LTFTs. The
injector offset matters most at minimum injector
pulse widths (it's making up for all of the actuation,
mechanical vs electrical, time-skew).
You may see that the injector is operating right up
against the minimum pulse width value. That would
bind your hand. Need that value to be sane, but
below the operating idle pulse width delivered.
Then if your idle trimming is fatter than before, figure
that can be attributed to the offset error. Like if the
idle cell LTFT moved from -4 to -8, 4%, the injector
offset error has contributer -to the total- a -4%
drift by swapping. Take the delivered pulse width
apart, it's the sum of (offset+airflow_calc). Or now
(offset+error+airflow_calc). The offset presently
being fixed and known, you can get the old airflow_
value known and be left with the error in mS. Go
subtract that from the present table (if trims went
more negative) and you should see the idle trims
move back to original (the delivered PW will stay put
at least in the closed loop area, but cold idle PW will
skinny up some).
If I were going at it like science, that would be a good
pulse train generator, a good fuel pressure gauge and
a variable pressure regulator, and a gram scale plus
plumbing. Run the injector at 10% and 80% duty on a
10mS period and take the two data points' line-fit
down to the axis. Then you'd be wanting the voltage
mapped out (coil and pintle-mass differences) and
the fuel pressure (pintle area). That's a mess o' data
to take, I can see why nobody does it (flow sells
parts, clean idle is for pussies
). But if you can get to happy by just shaving on the
offset table based on the car, in relative terms, it's
good enough, right?
The injector offset table might need to be changed
if the injectors are of a different construction, they
can vary in opening/closing time. That's something
you'd have to back into, once you think the main
flow is about right, based on low-pulse-width fuel
errors observed (like idle fuel trims movement).
If you're going way up in injector size you may also
need to lower the minimum pulse width, if that was
anywhere near the idle / decel minimums you see in
driving. If you leave that alone and step up (say) to
42s from 26s, your minimum squirt will be about 60%
fatter and this might make it impossible to idle clean
(can't trim past a hard stop) unless you take out that
bind
Heres a question; Doesn't each injector have its own offset values as determined by the manufacture? If this is the case, why can't we readliy get this information? I am working with a set of Motron 60's that are giving me some idle issues.
Seems to me that IFR's and IOS should be a set values per injector......No??
Thanks for your post!
Makes me want to go out and get an injector flow bench and figure it out once and for all! The injector offset sounds like we need to do a flow test but at varying voltages.
I seen some people on the forum complaining that they couldn't find it so there may be a problem. It's around 47 MB, I'll test it when I get to the shop where I have broadband later.
Then go to "Download Updated V1.19 Software" etc.
but not the ones I plan to use (Delphi 32#). It might
help some folks. I may end up sending mine out to get
cleaned & flow-tested if I can find a shop that will do
dynamic flow testing at multiple pressures and voltages.
If anyone has a reliable, cooperative contact of that
sort I'd like to know; the places I've turned up on the
Web don't seem to be science-project-oriented (or at
least, not according to what they present). PM me, if.
