SES Question
Old Sep 7, 2002 | 03:31 PM
BensZ28's Avatar
Default SES Question
SES came on today while i was just sitting there in a parking lot, went to autozone and got the code: P-1415, when it decodes it says "Secondary Air Injection (AIR) System Bank 1". I dont know anything about that???? What do I need to do about it?
Old Sep 9, 2002 | 09:12 AM
Sparky's Avatar
Default Re: SES Question
Your car will occasionally run a test to see if the AIR system is working ok. It uses O2 sensor readings to determine if it is seeing the added O2 from the AIR system. Since you're not getting codes on both banks, I'd assume it could be a bad drivers side AIR check valve or a lazy O2 could also possibly trigger it.
Mark
Old Sep 9, 2002 | 02:42 PM
BensZ28's Avatar
Thanks that clears things up, so do I really need this checked out or fixed? there are no emission checks in my area...any other long term affects?
