TPS Adjustment?
Old Sep 9, 2002 | 08:20 PM
CB99SS's Avatar
Default TPS Adjustment?
How do you adjust your TPS. At closed it shows .64. You want it close to .5 correct? I've tried moving the TPS sensor, but it doesn't move. Should I back down the Idle set srew?
Thanks
Old Sep 9, 2002 | 09:06 PM
wrencher's Avatar
wrencher
Default Re: TPS Adjustment?
Ever made a tps adjustable with a dremel?
Old Sep 10, 2002 | 09:59 AM
jimmyblue's Avatar
Moderator
I've done it with a rat-tail file
(on a Lincoln 5.0). Just turn the
holes into slots that give you
circumferential play in the direction
you want to go.
When you do that, then you also have
to make sure you're not over-the-top
on the WOT end.
