WOT Voltage?
Old Sep 11, 2002 | 11:38 AM
Gold Phoenix's Avatar
Default WOT Voltage?
What is the WOT voltage?
Old Sep 11, 2002 | 11:45 AM
unit213's Avatar
Administrator
Default Re: WOT Voltage?
4.7
unit213's Avatar
Administrator
I should mention not to exceed 4.7v. Mine is at about 4.63v if I recall correctly.
Old Sep 11, 2002 | 11:52 AM
OvalHunter's Avatar
I believe anything over 4.7 sets a code. The PCM in my car says 99% throttle position at 4.04 volts and 100% at 4.06 volts.The goal is to get the throttle blade as close to 90 degrees open as you can without hitting the 4.7 volt threshold. This is for air flow purposes, not changing when the PCM thinks your at WOT.
Old Sep 12, 2002 | 12:07 AM
I would like to use NOS's TPS Progressive controller which requires a WOT voltage of 4.7 to 5 volts
