Why does my car redline at 6200 when I used LS1 edit to program a 7000rpm redline?
I don't get it. Even after LS1 edit programming....my car isn't revving as high as its supposed to.
I programmed a 7000rpm rev limiter across the board, yet in second gear the car won't go above 6200rpm or so.
What gives?? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Anyone else heard of or seen this problem??
<small>[ September 14, 2002, 09:03 PM: Message edited by: verbs ]</small>
Re: Why does my car redline at 6200 when I used LS1 edit to program a 7000rpm redline?
make sure you changed the limiter in all the places. there is more than one place it needs to be changed.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Glenn98ZM6:
<strong>make sure you changed the limiter in all the places. there is more than one place it needs to be changed.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I did double check and still no dice <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by WicketMike:
<strong>you have to change the tables also</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">been done too. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Are you running an aftermarket tranny or six speed?
If so change your rev limit in neutral to 7Krpm. I had the exact same problem when I switched to an aftermarket tranny. Changed the neutral rev limit to 7Krpm and all was good. With the M6 harness unplugged the car thought it was in neutral.
Something to check.
Chris
Something to check.
Chris
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris ARE 360:
<strong>Are you running an aftermarket tranny or six speed?
Something to check.
Chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Stock tranny Chris....I'll try 7000rpm in neutral and see what happens.
Something to check.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Blackbird:
<strong>do you actually bang the limiter or does it just stop pulling?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I bang the limiter @ about 6100-6200rpms in 2nd gear.
<strong>any updates?
cheers,
Chris</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Nothing at all....still trying to figure out why the car isn't shifting where its supposed to.
I'm going to try to reset the CPU and start over I guess <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I'm out of options.
I'm going back in for tuning on the 28th.
cheers,
Have you ATAPed it to verify the 6200 shift point? It could be that you have a really slow tach.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by red53gmc:
<strong>Have you ATAPed it to verify the 6200 shift point? It could be that you have a really slow tach.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">ATAP is how I figured out I have the problem <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
No matter how I accelerate in 2nd gear, whether it be WOT or a slow crawl, I always hit a rev limiter at 6100-6200rpm or so. Every other gear seems to be fine. And yes, the tach is a bit slow in every gear, but I've verified using autotap that all the other gears are climbing to the 7000rpm limit.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by verbs:
<strong>I don't get it. Even after LS1 edit programming....my car isn't revving as high as its supposed to.
Anyone else heard of or seen this problem??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Check these places..
Under the idle and limiters tab -
Park/Neutral Cutoff=7000 Resume=6950
Rev Limit by Gear tab -
Set all the cutoffs to be 7000 and Resumes to 6950
I was planning on getting ls1 edit but this thing doesn't sound user friendly at all..isn't there a manual with it or something online at the carputing site ...??For the money this thing costs you should be able to just get an email answer from the company that makes this thing..your car is an m6..?? I think I am going to wait for next spring and see if they have any alternative programs out to this.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MY99TAWS6:
<strong>your car is an m6..?? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yep. I've had other buddies use LS1 edit and at times get no or little results from massive changes.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by John B:
<strong>It ran to 7K on the dyno...what did you change?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It ran to 7K on the dyno in 4th gear. Every other gear hits 7K but for some reason 2nd gear doesn't.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by chuckster:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by verbs:
Set all the cutoffs to be 7000 and Resumes to 6950</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Already did this one:
