Which N/A induction pieces work better with PCM learning?
I call <img border="0" alt="[bullshit]" title="" src="graemlins/gr_bs.gif" /> , unless someone can elaborate here. FWIW, I "gained" 3RWHP by dynoing stock TB, swapping to ported version, and immediately re-dynoing. Very disapointed compared to people posting 6-10RWHP gains on HCI engines, and my "gain" was all above ~5000RPM.
The key here is it needs a big enough sample of data in order for it to stop readjusting itself all the time in order to find its "sweet spot".
That is basically the easiest way I can explain it. The reason your probably not seeing the gains is that it doesnt know (yet) what the correct fuel/timing should be in order to run optimally. You just have to give it some time and drive it 50 or so miles so it can get a large enough sample for its PCM algorithms.
The reason your not seeing the gains when you put the new TB immediately is that the computer is running based on the data on the airflow from the previous TB. It just needs to make more adjustments based on the additional airflow in order to get back to its "sweet spot'
Does that make sense to you?
<small>[ September 15, 2002, 03:41 AM: Message edited by: cobray ]</small>
The air has already been measured by the MAF before it enters the throttle body...?
