HELP!!! Did !Wires mod and now car wont start
I did the dressup mod where you reroute the wires on the passengers side of the engine compartment down inside the fenderwell. I thought I got it all back together the right way but now when I go to crank it, it just turns over but no fuel pressure. The fuel gauge is not doing anything either but I know I have a 1/4 tank (put gas in last night).
I thought all those wires were for stuff like the fans and crap.....should still "run" even if they had been off right?
Chris
<small>[ September 15, 2002, 08:31 PM: Message edited by: 2001CamaroGuy ]</small>
Chris
Re: HELP!!! Did !Wires mod and now car wont start
For the record, here is what he did..
http://216.112.25.134/poltergeist/F-...gerWireMod.htm
Pretty straight forward.. if you connected all the wires together right AND made good solder connections then you should be fine..
If you have a bad connection or even worse mixed up the wire then you have to re-trace.. hopefully you tried starting the car before you sealed everything back up..
Re-check everything.. the tough one will be if you switched the pink wires.. Also, since all those wires go to the front of the car I cant see them controling the starter or even more so the fuel pump.. but im no expert thats for sure.
Maybe a unrelated wire was knocked loose? Did you test the wire to the fuel pump to see if it is getting current? Did you disconnect the battery before doing this mod?
These are the times i wish i had a Helms manual <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2001CamaroGuy:
<strong>I fixed it last night at about 11:30 at night. I had a pair of "pretty pink" wires backwards. Switched them and I was off and running. Thanks for the help guys.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Glad to hear.. im still surprised those do anything with the fuel systems.. ???
Its not like we didnt warn ya about them pink wires <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
looks better now?
looks better now?
yeah....it looks alot better....no more wires... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
its always the stupid pink one....even in the movies....."don't cut that one!!!" BOOM <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
