Rev limiter with 1:85 rockers
I just purchaced SLP 1:85 rockers with LS6 springs and I was wondering what RPM I should set my rev limiter too with LS1-Edit? (M6)
Re: Rev limiter with 1:85 rockers
The 1.85 will not give you much more RPM range. Whatever you have it set at, I wouldn't expect more than a couple of hundred RPMs more in the power band. This is because the rocker arms do not alter duration to an effective extent. They do however make more lift, and should give you more power throughout your current RPM range.
