How to set Rev Limiter with LS1edit?
Thanks, Justin
Engine --> Idle&Limiter --> Idle Speed (keep the higher idle points for cold starts)
Engine --> Idle&Limiter --> Rev Limit By Gear (All cutoff to your limiter. All Resums at Cutoff - 1)
Air Codes:
410
412
418
1415
1416
I can't help you with EFI live question. I use A-tap.
ETC: Easy tom cat
ETC: Extra-Terrestrial(sp?) Convention
ETC: Easy to critisize
I think it stands for Electron Traction Control. I know that it is for the vetts only, so us slow F-bods don't play with it.
About the air codes, look them up in
Engine Diagnostics --> Hardware Diagnostics
Select the code from the drop down menu. Toggle the SES code to Off, and the Error Mode to Type X.
Good Luck
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Justin
