PCM Firm Shift Mod
This mod is for 4L60E or 4L80E only! Use a triple throw switch. In the first position, use a resitor with a 27.2 ohm value. (Position 1 firmness) The second position, use no resisitor. (Off position) The third position use a 5.2 ohm resistor. (Position 2 firmness) Remember all this mod does is change the amount of current going to the pump. The less resistance, the more current to the pump, which equals a harder shift. Beware this could cause pre-mature failure of your pump overtime. If you really wanted to get kinky, you could always run position 3 straight, without a resistor for a killer shift. (Race only) Anyways, back to install. Remember 98 & up 4L60E's, the car should be off before putting the switch in the desired position. Now find your (White harness) on your PCM. Connect to terminal #36(Light Blue w/White stripe) for position 1. Connect to terminal #39(Red w/Black Stripe) for position 3. Mount your switch & your done. All feedback & questions welcome!
