VE table shape
If you see your closed loop tune acting up when the temperature changes it's not cause the sd tune can't compensate for temperature. I would look for a fix in the charge temp bias vs airflow table.
As far as the charge temp bias vs. airflow table, I won't even begin to assume I understand what's going on there.
how to look at it . like draw a line thru were your at at wot...
Or is there a different way to do that?
My VE table is set up for 14.68:1 in the idle, part throttle, cruise areas, and I run about 12.2:1 up to 4800 RPMs and lean it out to 13.0:1 for the rest of WOT.
So your VE is not actually your VE (thats whats confusing me). In this method, if you want a rich mixture you can potentialy get a 100%+ VE which is completely false in the definition of VE (unless you have built race engine)
Side note: I believe megasquirt works that way, by using the ve table to manipulate a/f ratio since it doesn't have a seperate desired a/f multiplier table. I think.
It makes perfect sense to have the 14.7 table and then have a multiplier on top of that for individual trimming of each point. Is this how it is done?
Also, is there a table for acceleration enrichment?, i.e. rapid change in TPS reading and quick RPM increase... How much lag is there in the system? If you accelerate from 1000-6000rpm in 1 second as opposed to 5 seconds your going to need to almost predict the point ahead of where your at.
As for acceleration enrichment, i don't think the stock programming does that, but i could be wrong there. There is an accel enrich tab in hptuners but I think that is only used with their speed density enhanced operating system, which their website says has a ve modifier based on tps.
Also, the VE table values aren't exactly a percentage as I understand them, as they can (and sometimes do) take on values greater than 100, even in N/A applications. If you'll look at my table, you'll see that my car peaks at 4800 RPMs with a value damn near 100, but the car is stock internals, so that right there should tell you that this isn't simply a percentage value.
And as I stated a disadvantage to SD tuning, there is also a disadvantage to MAF tuning. MAF sensors have a flaw, and that is that they measure the airflow no matter which way the air is going through it. People that run big cams know this all to well as a rough idle (more commonly referred to as lope). This is a sign of reversion, as some of the exhaust is coming back through the intake tract during the normal operation of the engine (mainly only seen at low RPM operation).
That's why you'll see people with big cams running SD tunes, as you don't have to deal with the reversion of a big cam. Chad (Black02SS on here) runs a fairly sizeable cam (Futral F-13), and his idle is really quite nice. He also knows what he's doing when he's tuning his car (he runs an open loop SD tune, and is the reason I run one too).
If you want to see just how much exhaust reversion affects your car, check into the Harrop 8-TB intake setup. Since your plenum is essentially the atmosphere, there really is no reversion. There's a video clip floating around on here with a stock cube 346 LS1 running some ungodly cam (huge duration on a 106 lsa) that idles pretty nice.
Just some food for thought...
Here is what im gathering so far..
Open loop = runs directly off VE table.. nothing else (for fuel that is)
Closed loop= runs off VE table and modifies VE table to achieve 14.7 at ALL times.
Im trying to find the value that commands or modifys the PCM from sending 14.7 afr to the desired AFR. Is the only place this can be modified the VE table? So you look at your AFR and adjust your VE table according to that? And thats all the control you have?
Yeah, for transients i would think Acceleration enrichment is a MUST! For pure drage racers its not as big of a deal.. but for those that modulate the throttle i think its invaluable.
And yes, the CAM change is the reason i would like to change to either Closed or Open loop SD
The one thing you have to watch out for is that your VE table will vary based off of your commanded A/F ratio when tuning in open loop. i.e. If you tune your VE table to a 13.0 A/F ratio across the board, your VE table would look different than if you tuned it to stoich across the board. This has something to do with some back calculations that the PCM performs based on the commanded A/F ratio. That's why I'll always recommend that you tune your car like you drive it (as in don't disable PE mode, etc when you are tuning it).
As for closed loop operation, it doesn't really modify the VE table. It just uses the fuel trims as decided upon by the O2 sensors, which aren't terribly accurate with headers (and why I don't use them at all on my car).
Don't forget, there are also spark adjustments to be made, and they will affect your final A/F ratio as seen by the wideband O2 sensor downstream. So you basically have to get your fueling in order first, then mess around with spark, then readjust your fueling to match the new spark tables. For heavy throttle transients, you also have to deal with Burst KR, which can become quite confusing.
I think my head is gonna explode...
That helps. I know what i want its just a matter of learning how to use the program to achieve it.
Is there a write up that just has a few sentence explanation of each table.. I can figure it out from there..
Also, i am definately leaning towards Open Loop unless i can wire in a Wideband to accurately simulate a narrowband... and if that would help... If not, when tuning you connect the LC-1 to the HP module and just tune from there?
If you want a writeup of each table, the hptuners help menu is pretty good for that.
