what should be changed with edit????
Old Sep 17, 2002 | 10:57 PM
thechef's Avatar
Moderator
Default what should be changed with edit????
hey guys help me out i just had the mods in my sig done and i am having edit sessions to get the car tuned and i have no idea what is being done that really make a differencehere is what i know has been changed
ses codes/light turned off
skip shift turned off
fans turned on earlier
gear ratio changed to 3.73
idle set
something in the abuse mode changed torque to 600ftlbs @ 7000 and 0
rev limiter to 7000
what else needs to be done please help me understand so i know what is being done to the car
and i think the timing was set to
thanks rob
Old Sep 19, 2002 | 11:20 AM
thechef's Avatar
Moderator
Default Re: what should be changed with edit????
come on guys someone share with me <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Sep 27, 2002 | 11:40 AM
thechef's Avatar
Moderator
ttt <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> <img border="0" alt="[boring]" title="" src="graemlins/gr_zzz.gif" />
Old Sep 27, 2002 | 02:45 PM
NoGo's Avatar
According to your list of mods, these are the things that I would change. But of coarse, it depends on the shop.
MTI Lid - No programming
K&N - No programming
T1 Cam - Idle Limiters Raised. Rev Limiters raised. Possible drilling of TB. Possible ignition advance at low RPM changed.
SLP LT's - Possible adjustment to MAF delivery tables
Y-Pipe - No programming
Magnaflow Catback - No Programming
U/D Pulley - Possible Cooling Fan Temp Change
3.73 Gears - Gear Ratio Changed
Clutch - No programming
And just for the heck of it....
Dyno Tuning of Power Enrichment tables to ~12.8 a/f ratio
Dyno Tuning of Ignition Advance
And that would about wrap it up (if I haven't forgotten something).... for an M6 <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
