Ltrims +25% i need help!
Old Sep 27, 2002 | 01:13 PM
slick98ta's Avatar
Default Ltrims +25% i need help!
I'm a little confused here.On the A-tap i checked the boxes that said Lterm B1 and Lterm B2, i think thats what it said.
Anyway, they both said at idle 25% and never changed when i gave it gas.If this is right is my car lean or rich?Or whats wrong here.
Also,on a-tap how do you check the IAC counts for idle?I can't find that.
Here's my list of mods to see what i'm dealing with:
LS6 intake
Ported MAF
Ported TB
Direct flo lid
Mac headers
X-pipe w/ dumps
Vig. 3200
3.73 gears
Thanks
Mark
Old Sep 27, 2002 | 01:37 PM
1slowCamaro's Avatar
Default Re: Ltrims +25% i need help!
Mark read the post "How to richen up Ltrims and put O2s at zero." I have the same problem.
Justin
Old Sep 27, 2002 | 03:38 PM
JR HAWK 9's Avatar
means you are extremely lean and will be throwing a code pretty quick. LTrims are only adjusted up to +/-25% and after that you will throw an SES light.
The pcm is adding 25% fuel to try to get you back to where you should be at part throttle..14:1 a/f ratio
Paul
Old Sep 27, 2002 | 03:52 PM
NoGo's Avatar
My guess is your ported MAF is not reporting enough air flow.
Put the stocker back on (if you have it) and see if the problem goes away.
Old Sep 27, 2002 | 04:39 PM
Stu's Avatar
Stu
Dont just read them at idle....Drive it around for awhile.
Get a bunch of cruisin miles. If it doesnt straighten out and you are set on the ported MAF then get a MAF-T.
Stu
Old Sep 27, 2002 | 04:57 PM
slick98ta's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JR HAWK 9:
<strong>means you are extremely lean and will be throwing a code pretty quick. LTrims are only adjusted up to +/-25% and after that you will throw an SES light.
Paul</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thank you!
Your right and i did throw a ses light.It was PO171 and PO174 which are lean bank 1 and 2.
I didn't know what was going on because I always ran a ported MAF and TB,then i put on the LS6 intake and got the codes.And I checked the intake 100 times and it has no vacum leaks so I take it its because of the maf,TB and intake.
Last weekend I put the stock MAF and TB on and the codes went away so i thought it was one of the two.
Whats weird is ,i went to the dyno and on the wideband it started out lean,it was 12.9.1 at 4300rpm's then slowly got rich going through the rpm's til 6500 running 12.4.1. So I think its lean on the lower rpm's.Also those wideband air/fuel #'s are without the ported MAF and TB.So with the ported MAF and TB I guess i'm extremlly lean.
Thanks guys for the help!!
I'll be getting a MAFT soon.
BTW: What if i just put my cam in,wouldn't that richen it up?
Mark
Old Sep 27, 2002 | 05:17 PM
98TAauto's Avatar
mine were +24 with the cam and ported ends.. i put the stockends back on and they dropped to -3 to 0 part throttle <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
those ported ends make things all screwed up. With edit you can richen or lean your car anyway you like <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Sep 27, 2002 | 05:40 PM
NoGo's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by slick98ta:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JR HAWK 9:
Mark</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">On the dyno, you may have run into the Cat Over Temperature protection, which will tank your car into the 11's for a/f to protect your cats.
With the ported MAF, the cam will actually make the problem worse. The more air that you flow, the bigger the problem is going to get. Ported MAFs become less and less sensitive to air flow the more air that you move.
For example. At 20 lb/hr of air flow, your ported MAF may only be about 10%, reading too low. However at 30 lb/hr of air flow around WOT it will be somewhere around 20 to 30% off.
Either calibrate your ported MAF in with Edit, or an MAFT, or run a more accurate MAF, like the stocker.
Good Luck
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Sep 27, 2002 | 05:54 PM
slick98ta's Avatar
Yeah,I think for now i'm going to put the Stock MAF back on,and hit the track and shoot for a 12.0 <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Last weekend was a 12.20 @ 109.8 and the weather is getting better everyday,so we'll see.
Thanks again guys for your help
Old Sep 27, 2002 | 07:17 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Stu:
<strong>Dont just read them at idle....Drive it around for awhile.
Stu</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes!
