Flashing SES light......HELP!!!
Old Sep 18, 2002 | 07:00 PM
5LETR's Avatar
Default Flashing SES light......HELP!!!
Right ABOUT 5000rpms(doesn't happen at any other rpm) my car hesitates for a second and then the SES light flashes several times and then is gone. I was told it was a misfire so I put in new plugs(old ones looked fine) and it is still going on. I am going to go back to my factory plug wires tonight to see if that helps, I have been using the Taylor 10.4mm for several months. Has anyone had this problem before? I have a 2001 TA with 30,000 miles and this just started. Any help would be greatly appreciated.
<small>[ September 18, 2002, 07:39 PM: Message edited by: 5LETR ]</small>
Old Sep 19, 2002 | 06:32 AM
98blackSS's Avatar
Default Re: Flashing SES light......HELP!!!
We need to look at some of your atap readings... Got access to one?
Old Oct 2, 2002 | 08:27 PM
5LETR's Avatar
I had the computer checked and here are the codes it pulled.
History data shows 508 misfires on #8 cylinder and 18 on #1 cylinder
P1040 abd P1060 codes onboth #2 O2 sensors with insuffecient activity( I have O2 simms)
P0300 engine misfire @5896rpm @71 mph
P1133 and P1153 Insuffecient switching on both banks #1(front) O2 sensors.
I put in new fuel filter and no change.
Any ideas?
<small>[ October 02, 2002, 08:30 PM: Message edited by: 5LETR ]</small>
Old Oct 3, 2002 | 10:37 AM
superchargedZ's Avatar
Have you changed the PCM at all?
Jason
Old Oct 4, 2002 | 08:56 PM
ragtopws6's Avatar
What's your knock sensor reading? May be running a little lean?
Old Oct 16, 2002 | 10:09 PM
5LETR's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by superchargedZ:
<strong>Have you changed the PCM at all?
Jason</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No, no PCM change. I have reset it before. I have swapped around the plug wires and will do the same with the coil since I have found out it is the #8 cylinder. I put in new plugs right after the problem started and the old TR6s looked great, but replaced them anyway.
