9psi with 100 octane. Set timing to what?
We ended up with 24 degrees total timing and zero KR blasting down the street on 92 octane. We left the A/F very conservative becasue we were using O2s for tuning. They were still running about .94-.95.
We will see hopw he does at BG this weekend, and then play with it some more at Norwalk on the 27th.
If you are still on the stock bottom end, I would keep you total timing around 18-20 deoending on fueling. If you are not seeing any KR, then creep it up a little. Whatever you do, do not defeat the knock retard sensors!
Todd
i have lower compression pistons ( about 9.4 :1) and i have my timming set to 27 deg!
your best bet is to tune on a dyno with a wide band . this way you could dial in your A/F too.
good luck.
