Need to replace crankshaft position sensor, any special brand?
Old Jan 28, 2006 | 04:14 PM
SDB's Avatar
SDB
Default Need to replace crankshaft position sensor, any special brand?
Never had to replace one of these before....any "preferred" brand? Any helpful hints on how to replace?
SDB
P.S., car contuinually sets a code for CPS...i have EDI Live Pro and autotap. I clear code and it IMMEDIATELY ste the SES again, and I did the crankrelearn three times with no luck. I figure it has to be the sensor (never replaced it in 6 years).
Old Jan 28, 2006 | 04:19 PM
Mr. Luos's Avatar
Something like that....GM parts.
Old Jan 28, 2006 | 04:37 PM
Dmoney's Avatar
You have to remove the starter to get to it. Two bolts one you can see, the other is way up in there need an extention to get to it.Before you go and do that, make sure you haven't burned any of the wires that go to the crank position sensor. Make sure they're not touching the manifold or the primaries on the headers on the passengers side. Mine weren't cut but burned from the inside. Rewired and all is well. Did not have to replace the sensor.
Old Jan 28, 2006 | 05:09 PM
horist's Avatar
out of curiosity did you recently swap PCMs? or recently have a mail order tune or such done?
As for preferred brand... just go w/genuine GM parts
Old Feb 3, 2006 | 11:07 AM
SDB's Avatar
SDB
got it swapped easy enough, but it still thows the p1336 code...did crank relearn 3 times and cleared the code 3 times...still immediately thows the SES light comes back on....getting a trouble shooting list from Mitchel program...
SDB
Old Feb 3, 2006 | 05:32 PM
Bad30th's Avatar
I got sent a bad PCM that would not perform the relearn, it was a mail order tune.
I bought a new factory PCM and had it flashed at the dealer with my stock tune, no problem getting the CPS relearn done on the new PCM.
Rob (Bad30th)
Old Feb 5, 2006 | 05:15 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
If you replaced the sensor, and it still throws codes, maybe check the wiring. It runs up the inner fender by #4 and #6... In that foil wrapped bundle.
Do you have a forged crank?
Old Feb 5, 2006 | 07:45 PM
SDB's Avatar
SDB
yes, Lunati 4.0 forged crank....
I will check the wiring as well..
SDb
