LT headers, rich mixture - chnage commanded AFR?
after LT installs + cam to change commanded AFR to leaner than 14.63:1.
It seems that with unburned O2 in the exhaust the cars run richer alhtough
the clode loop thinks it is okay. SO if one changed the commanded control point in lcosed loop, AFR to say 15.0:1 that might help to get inot the correct
range? What is wrong with that approach?
Thanks,
Gert
you getting something else?
And, is the commanded AFR the AFR you tuned in, or is
it being modified by fuel trims that are whacked by the
headers / cam / O2s?
You could tune for open loop and eliminate mistrimming,
or you could play with the airflow mode and proportional
fuel stuff trying to get better results given the O2s'
soggy response in headers cars. Whether the problem
is the cam or the coldness, you'd have to decide by
observing the O2 waveforms.
I think open loop is probably the easiest.
