Anything I can do for tuning w/o ls1 edit
Old Sep 23, 2002 | 01:45 PM
Willwork4mods's Avatar
Default Anything I can do for tuning w/o ls1 edit
I finally autotapped my car yesterday and some of the things were waaaay outta whack.
IAC counts were 70-80 (sugring to 135)
Fuel Trims were running lean on both banks.
Timing advance was around 37 degrees.
The car last time i dyno tuned was setup for a B1 with no heads and macs. We advanced the timing to around 7 (my car seemed to like more timing).
Now, that i have the heads and mms 229 cam.. these are the results.. is there anything i can do until i can afford another dyno tune?? or someone to use ls1edit on her.???
thanks
devin
Old Sep 23, 2002 | 03:05 PM
Ragtop 99's Avatar
Default Re: Anything I can do for tuning w/o ls1 edit
Lean: Remove ported MAF ends if you have them. That will help reduce your timing too.
IAC: If your idle speed is pretty close to your desired idle speed, enlarge the TB hole by 1/32". You can also turn the idle set screw a 1/2 turn open.
Timing: Reverse timing tricker. Use a resister inline from your IAT to make the PCM think the air temp is 75*C or higher (I forgot the size; the FI guys would know). That will pull about 3* at WOT.
Old Sep 23, 2002 | 05:03 PM
Thanks Ragtop.. i'll see if someone will swap my ported maf end s for stock. and adjust the TB a little. I'll see if someposts about the resistor size is someone else posts up.
thanks again.
Devin.
Old Sep 23, 2002 | 09:33 PM
StevieZ's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Lean: Remove ported MAF ends if you have them. That will help reduce your timing too. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I thought that if you removed the ported MAF ends that it would increase timing??????
Old Sep 24, 2002 | 08:06 AM
Ragtop 99's Avatar
With ported ends, the computer perceives less load and can use higher timing.
