change oil light?
Old Sep 23, 2002 | 08:20 PM
last of the Z28's's Avatar
Default change oil light?
hey guys i was cruisin around tonight and the change oil light came on then went off about 3 minutes later.the car is 2002 z28 stock with 4500 miles on it the dealer changed the oil at 3000.has this happened to anyone else?should i be concerned?is this a thing that goes into memmory or is it seperate from the pcm(so the dealer doesnt say im nuts)thanks <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Sep 23, 2002 | 10:13 PM
wrencher's Avatar
wrencher
Default Re: change oil light?
They probably did'nt reset your oil change light. Hold down your trip reset button for 12 seconds w/key on engine off & it will reset. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Sep 24, 2002 | 07:26 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
....or if you don't want to reset the odometer too, turn on ignition (don't crank) and pump the gas pedal to the floor 3 times..
