Help! O2's way off from each other.
if its reading .6 thru the whole run, then its bad.
but make sure its not just a couple of readings that are really low and throwing the avg. that low.. if you have 10 readings at .9 and then one at .01, take that one out
but if your logging a pull in one gear then they shouldnt be that far apart, cause one side is running exteremly lean!!
lean is usually .88 and below
u havent gotten any 02 sensor lights have u?
