O2 sensor going out? (P0154)
Old Sep 28, 2002 | 09:41 PM
StretchNutz's Avatar
Default O2 sensor going out? (P0154)
Autotapped a friend's car to see what the SES was from, gave code P0154, or "HO2S Circuit Insufficient Activity Bank 2 Sensor 1". Did a little logging and found out that the B2S1 sensor was at a constant 447, every now and then going up or down a couple points. Could his O2 sensor be taking a crap on him? Or is it a wiring problem? Any ideas? His car: 98 A4 z28, light bolt-ons (gears, fipk, borla).
This problem started after he had his tranny rebuilt, so I'm leaning towards something besides a bad sensor.
Thanks,
Drew
'00 Formula WS6
p.s. this thread was pretty informative, but that's all the search returned.
Old Sep 28, 2002 | 09:54 PM
wrencher's Avatar
wrencher
Default Re: O2 sensor going out? (P0154)
Check & see if it is connected, damaged wiring, or a broken o2. Pcm reference voltage is about .44 so the problem probably at the o2.
Old Sep 28, 2002 | 10:09 PM
NoGo's Avatar
ditto, O2's stuck at .4's usually means a dead O2.
