DTC P0106 anyone ever get it?
anyone ever throw this code? what causes it and how can it be fixed
thanks
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">The PCM calculates a predicted value for the MAP sensor based on throttle position and the engine speed. The PCM then compares the predicted value to the actual MAP sensor signal. If the MAP sensor signal is not within the predicted range, DTC P0106 will set...The pressure should be about 103kPa at or near sea level. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm not sure if this helps any. I could give you the 21 Tests/Steps given to the service techs to diagnose/fix this problem.
