**Update** LS1 Edit unable to get program my rpm limiter past 6300 rpms in 2nd gear
Well, as it turns out the shiftlight isn't bad at all.
After repeated LS1 edit tuning in an attempt to raise the rev limiters in every gear to 7000rpms, for some reason after the car gets programmed, every gear except for 2nd gear will be at the 7000rpm limit.
2nd gear refuses accept the 7000rpm limit from LS1 edit, and even though we program it to 7000rpm, the value that comes back is always 6300rpms.
So we think the LS1 edit program might have some bugs, something to do with the packets <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Anyone know why this is happing and how to fix it??
Re: **Update** LS1 Edit unable to get program my rpm limiter past 6300 rpms in 2nd gear
pcmdoc@surfree.com
Although I would think Xtreme should be contacting him instead since its a tuner shop version of LS1edit.
Someone has had to encounter this problem before <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
