LS1edit vs. HPP3 vs. Diablo
I'm no expert seeing as how I have none of the three programers, but I do a lot of reading so here's what I've picked up....
The hypertech is pretty much worthless for an M6 car. You can do fans and gears and use their "tune" program but it really doesn't do anything. I know nothing about the diablo - still doing the reading on that - but seems more promising than th hypertech.
LS1edit is the best because you can do everything. However since you can do everything, that means you can mess things up to. I believe the manuals pretty much suck for Edit - check www.carputing.com and I believe you can download the manuals and check them out. I am no tuning expert or anything, but by reading all these boards and stuff I think you can surely pick up enough to tune correctly. The way I look at it, Edit costs $550, but if you pay someone to program your car more than once, you have allready paid of a copy of edit for yourself. I would go with edit just because I plan on doing mods at seperate times and I will need to delete codes or turn off ses lights, but don't need major reprograming.
Hope some of that stuff makes sense and helps.
http://www.ls1.com/forums/showthread...5&pagenumber=1
