Can I replace stock O2 with Wideband O2 Sensor
Old Oct 13, 2002 | 06:33 PM
BB's Avatar
BB
Default Can I replace stock O2 with Wideband O2 Sensor
Can you do this? Granted you won't get A/F from this but at least you could rely on your O2 reading for tuning.
Old Oct 13, 2002 | 06:36 PM
JAS's Avatar
JAS
Default Re: Can I replace stock O2 with Wideband O2 Sensor
No.
Output is different.
Old Oct 13, 2002 | 07:26 PM
wrencher's Avatar
wrencher
It's already on some vehicle's but many more soon to come ? GM's ? yes
Old Oct 13, 2002 | 09:06 PM
BB's Avatar
BB
So, what is happening with the car when the narrow band O2 sensors are out and you put a wideband in?
I assume the narrow O2 sensors are just disconnected during the dyno? I guess at WOT this is not a problem because you are in Open Loop and the O2 sensor data is not used.
Do I understand this correctly?
Old Oct 13, 2002 | 09:39 PM
kp's Avatar
kp
Most dynojets with a wideband have a tailpipe sensor so you dont have to remove the stock O2s.
Yes the car will just stay in open loop if you pull a front O2 sensor. Some aftermarket in-car wideband meters will output a 'fake' narrowband signal to keep the PCM happy. I built one of these: http://personalpages.tds.net/~kpevin/ a while back and I am happy with it. Makes tuning a whole lot easier..
<small>[ October 13, 2002, 09:43 PM: Message edited by: kp ]</small>
Old Oct 14, 2002 | 07:04 AM
BB's Avatar
BB
kp: Thanks for the reply. I think I saw reference to your kit on the DL for LS1Edit too. Based on your website I agree it would be better to have the RPMs as well.
<small>[ October 14, 2002, 07:05 AM: Message edited by: FlamnTA ]</small>
