Nasty (Dangerous) Surge
The car does now have a TR224 cam in it. It was stock before. Needless to say idle is a little low and rough. I'm new to the whole cam tuning thing, but I'm quicly learning (drill TB, set screw, etc.).
HERE IS THE PROBLEM. After getting the car idling barely decent, I decide to pull out of the garage and turn the car around in the street (her maiden voyage). The idle was a rough 500 +/- but I could control it. About 1-2 seconds after putting it into drive the IDLE RAISED TO ABOUT 2,500 TO 3,000 AND STAYED THERE! Like a stuck throttle cable, but that's unlikely since it raised on its own and I had not even touched the accelerator. From then on, everytime I put it into gear (fwd or rev) the same thing happened. Made it almost impossible to control just to move the car.
I am fighting a MAP problem (P0108 -- high voltage) and maybe that has an effect. I'll disconnect the MAP (force a P0107 -- low voltage) and see if that changes the circumstances.
Has anyone experienced a problem similar to the one noted above. Any insight?
Thanks in advance.
