NO cominication with ANYTHING?
Old Feb 1, 2006 | 02:13 PM
usnskeet21's Avatar
Default NO cominication with ANYTHING?
I just finished getting my 408 in a 99 vette. I was ready to light her off for the first time. I turned the key expecting to hear the fuel pump and there was NOTHING. temp gage reads 260 and fuel says nothing (full tank and its 60 here). I try to check codes and there is NO comunication with any systems. the ground strap by the started is hooked up to the block and the 2 on the drivers side are hooked up to the block. I sent the PCM to jeff at PCM for a safe tune, could something be wrong there? Any ideas on where to check ?
Old Feb 1, 2006 | 02:24 PM
SSnakekiller's Avatar
Time to pull out the voltmeter?
Could be a number of things
I'll state the obvious...CHECK OVER ALL CONNECTIONS
Old Feb 1, 2006 | 03:20 PM
usnskeet21's Avatar
checked over ALL conections looked back behind intake. i removed 4 ground straps and replaced 4 ground straps. I am baffled by the fact that the car doesnt see ANY system... pcm, bcm, hvac. the whole list that it scrolls through in diagnostics mode ( NO COMMS ) . Could something be wrong with the tune on the computer?? maybe jeff type in a wrong # ( i dont know ANYTHING about those. does it require the vin #??)
this was what i dreaded most out of this swap and electrical problem..
Old Feb 1, 2006 | 03:50 PM
TAQuickness's Avatar
Did you check all the fuses? Did you check the battery to make sure it's good? Did you over torque the pcm wireharnes bolts? Do you have a spare pcm you can install?
Old Feb 1, 2006 | 06:35 PM
usnskeet21's Avatar
checked all BCM and pcm fuses.
batter is in fine. Enough to make one fan turn on when i connect the battery.
nope they are in there snug.
i could get one but wouldnt it have a different vin and cause things to get even more confused??( if thats possible )
Old Feb 2, 2006 | 12:04 PM
allthrottle&nobottle's Avatar
Per our telecom.
Charge up the battery..........
Try to bring the BCM out of its sleep mode...........
And here is some reading!
My Fun.......
http://forums.corvetteforum.com/show...um_id=1&arch=1
http://forums.corvetteforum.com/show...bcm&forum_id=1
