another resetting pcm ?
Old Oct 25, 2002 | 07:55 PM
waverider's Avatar
Default another resetting pcm ?
Will resetting the pcm buy pulling the pcm bat and pcm ign fuses effect the odometer? You don't loose your odometer reading?
Old Oct 27, 2002 | 12:44 AM
SSINFUL's Avatar
Default Re: another resetting pcm ?
Not yer "permanent" odo readings. That # stays even when ya unplug the battery...
Old Oct 27, 2002 | 08:22 AM
JS-Z71's Avatar
Will not delete the permanent in the PCM?
