#8 Injector Fault with EFILIVE
Old Oct 31, 2002 | 04:42 PM
kick_*ss's Avatar
Default #8 Injector Fault with EFILIVE
Other then the obvious, I just wanted to check if this is a known bad read.
It only happens on my car, so I am pretty sure its the injector.
So do I have to replace all 8 or just the bad one.
Old Oct 31, 2002 | 11:02 PM
SIKLS1's Avatar
Oz Director
Default Re: #8 Injector Fault with EFILIVE
Send the log file to paul@blacky.co.nz
So he can look at it for you.
Drew
Old Nov 1, 2002 | 08:10 AM
kick_*ss's Avatar
ok, its faults instantly every time I hook up efilive and start it with the injector fault setup on the bottom with the little green lights on the bottom. #8 every time, and 1-7 are sitting at OKs.
I am going to move the #8 injector tonight to #1 to see if the fault moves with it. If so, I will pickup a new injector.
Old Nov 1, 2002 | 01:40 PM
kick_*ss's Avatar
Interesting, I just ran EFILive on LunaticTA's car at lunch and injector #8 also shows a fault.
Anyone else with a TR224/.561/112LSA see this happening?
