6 point diff. between b1s1 and b2s1 on atap - why??
mine usually read .88 on one side and sometimes .94 or so on the other..
usually they are .04 or so apart so i wouldnt worry
<strong>Did some atap runs and at wot my b1s1 consistently averages around .95 volts with my b2s1 consistently at .89 volts. I have zero knock and consistent 28 deg. of advance. What would cause this discrepancy and what would you look at first to fix it? Also I have no ls1 edit or any tuning.
Mods are is sig below. I also have the flp headers with orp with o2 sims.
thanks,
steve <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Try a recording on a run that does not include any idle.
If the numbers are closer together then it is due to the makeup of cam and heads.
thanks,
<small>[ November 01, 2002, 12:07 PM: Message edited by: SB ]</small>
