LS1 Edit Question...ASAP!!!
Old Nov 4, 2002 | 01:18 AM
INSSANE's Avatar
Default LS1 Edit Question...ASAP!!!
I'm taking my car in Mon. morning to get a LS1Edit quick tune.
I believe they delete TQ management, raise limiter and adjust shift points.
Speed Inc (ls1speed.com) is doing it, so I trust them. I'm also having them raise the idle a bit.
My car has:
ST3500, shift kit level II, Grott headers (dual cutouts = open headers), and that's about it for big mods.
I'm taking it in open headers, and will have an ASP UD pulley on it soon too.
On my 2-3 shifts at the track I bounce off the limiter BAD. What are optimal settings for my setup?
Plus, is there a tiny thing or two they can tweek while in LS1edit...keep in mind it's a $150 tune, not the full blown $400 one (that comes with H/C in spring <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Thanks alot!!!
Nick
Old Nov 4, 2002 | 06:59 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Default Re: LS1 Edit Question...ASAP!!!
I had to do a lot of logging/tweaking to get my shift points set up right. The thing that helped me the most was to set the limiter to 6300. I'm running +4mph on 1-2 shift and +2 on the 2-3.But I'm using a HPP3 and have 2.73 gears/ST3500 so my settings probably wouldn't translate well for you assuming you're running 3.23s.
