Hpp3 won't deprogram with harness unplugged from motor....
Old Nov 7, 2002 | 06:29 AM
Damian's Avatar
LSX Mechanic
Default Hpp3 won't deprogram with harness unplugged from motor....
Right now I have the motor apart, however the PCM is still hooked up and getting power from the battery. I tried to deprogram the computer last night, but it seems as though the Hpp3 can't connect. What has to be plugged in so I can do this? Everything in the car lights up including the dash, so I know I have juice....TIA
Josh
Old Nov 7, 2002 | 07:01 AM
Camaroholic's Avatar
Default Re: Hpp3 won't deprogram with harness unplugged from motor....
When I build a programming harness, I follow the pinouts at LS1.com in the FAQ section. I hook up all the listed grounds, all the listed +12V battery leads, and then put a switch on the ignition wire. The only other wire needed is the OBDII data wire.
So, assuming you have all the grounds, battery leads, ignition, and serial data, then it *should* program.
Hope that helps!
Andrew
Old Nov 7, 2002 | 09:41 AM
Damian's Avatar
LSX Mechanic
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Camaroholic:
<strong>When I build a programming harness, I follow the pinouts at LS1.com in the FAQ section. I hook up all the listed grounds, all the listed +12V battery leads, and then put a switch on the ignition wire. The only other wire needed is the OBDII data wire.
Hope that helps!
Andrew</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks bro, that is EXACTLY what I need to know!
Josh
Old Nov 8, 2002 | 12:38 AM
Mekkadon's Avatar
ummm, this wouldn't happen to be the hpp3 you're selling me is it?? <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
j/k <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ November 07, 2002, 12:39 PM: Message edited by: Mekkadon ]</small>
