ECM locked after engine swap
Old Feb 5, 2006 | 06:37 PM
TchargedLS1TA's Avatar
Default ECM locked after engine swap
I just got done doing an engine swap in a 04 Silverado 5.3L and after having no battery power for a week, the ignition comes on and all tha accessories work, but the starter will not crank and the Theftlock lamp is on.. I also swapped out the ECM, but it was a Nelson tune.. Any ideas how to unlock it?
Old Feb 5, 2006 | 06:53 PM
rgvsierra's Avatar
so your original pcm works but the nelson one dosent?
Old Feb 5, 2006 | 07:04 PM
Dunno, i got burned out today so I will check tomorrow. It just seems odd that he would get something like this wrong..
Old Feb 5, 2006 | 08:12 PM
rgvsierra's Avatar
edit,
so it dosent even crank at all. then i'd guess something else other than pcm related.
Old Feb 6, 2006 | 12:55 PM
Just put the old ECm back in and same thing.. I can even get a DTC reader to connect to the truck..
Old Feb 6, 2006 | 01:16 PM
horist's Avatar
for the DTC reader, check to make sure you have power on the OBD2 port... see if your cig lighter works... if not the fuse is blown
Old Feb 6, 2006 | 04:17 PM
Theres power or else the DTC reader wouldnt come on..
Old Feb 6, 2006 | 06:37 PM
Anyone know where the purple wire on the starter solenoid comes from?
